Error saving data, status code: 503 when change $ to €
Quick response from support !
  • Energy function doesn’t work in version 1.0.979, there working on this issue
  • save button is not turning red when removing a section. However, remove the section and press the Save button even it’s gray instead of red, it should save. I’ve added a bug report for this and it will be fixed: http://bugs.micasaverde.com/view.php?id=763
My second day with Vera and very happy , running version 1.0.979
Some issues/bugs I had :
  • energy cost not available unlike version 1.0.616
  • when change Electric cost sign to € : Error saving data, status code: 503
  • can not remove section
please advise.
Wouter,
Hengelo,The Netherlands, Europe.
Hi wouter,
Like I explained in the email, for now, until the next firmware upgrade, the Energy function is not available, so also the problem with changing the currency. As for the remove section, just hit the save button after you remove it, even it’s not turning red.
error still exists also in version 1.0.987
Wouter
