I cannot save updates to anything in the Vera. An easy way to replicate is to try to update the name of a device, then hit save. The save operation take forever, but eventually returns either one of the two errors:
Saving local data …
Error saving data, status code: 12002
or
Error saving data, status code: 500
I’ve done all the usual things, restart luup, restart vera router, unplug without any luck. I’ve also tried deleting the device (an intermatic outdoor module) which does not seem to want to delete. I’ve added this device in the past, so I think my problems may be related to poor timing.
Background:
My Vera 3 has been running UI5 great for quite a while. I unplugged the vera to include a node to the system with the battery backup. I successfully added the node, shut down, and plugged back in. Then at startup tried to reconfigure the serial devices. When you run off battery the serial devices are not present and need to be manually reconfigured. I noticed that those (or anything else) would not save.
Any thoughts or workarounds to fix? Thanks!
