sebby
March 13, 2016, 5:28pm
1
I’ve been trying to troubleshoot some memory issues on my vera, and while i don’t think this is related, I wanted to make sure this plugin was working properly. when looking at my LupUPnP.log file and looking at only events with “01” status, i see this in my log after reloading Lua. that log entry stating the loop took X number of seconds always logs. is this normal or do i need to change something on my config?
01 03/13/16 11:02:58.292 LuaInterface::CallFunction_Timer device 65 startupDeferred took 8 seconds <0x2d328680>
01 03/13/16 11:03:03.704 LuaInterface::CallFunction_Timer device 66 startupDeferred took 7 seconds <0x2d528680>
01 03/13/16 11:04:07.180 LuaInterface::CallFunction_Timer device 65 loop took 6 seconds <0x2d328680>
01 03/13/16 11:04:11.690 LuaInterface::CallFunction_Timer device 66 loop took 5 seconds <0x2d528680>
01 03/13/16 11:05:15.263 LuaInterface::CallFunction_Timer device 65 loop took 6 seconds <0x2d328680>
01 03/13/16 11:05:17.618 LuaInterface::CallFunction_Timer device 66 loop took 5 seconds <0x2d528680>
01 03/13/16 11:06:22.181 LuaInterface::CallFunction_Timer device 65 loop took 6 seconds <0x2d328680>
01 03/13/16 11:06:25.592 LuaInterface::CallFunction_Timer device 66 loop took 5 seconds <0x2d528680>
01 03/13/16 11:07:29.082 LuaInterface::CallFunction_Timer device 65 loop took 6 seconds <0x2d328680>
01 03/13/16 11:07:33.742 LuaInterface::CallFunction_Timer device 66 loop took 5 seconds <0x2d528680>
01 03/13/16 11:08:37.170 LuaInterface::CallFunction_Timer device 65 loop took 6 seconds <0x2d328680>
01 03/13/16 11:08:39.646 LuaInterface::CallFunction_Timer device 66 loop took 5 seconds <0x2d528680>
01 03/13/16 11:09:47.191 LuaInterface::CallFunction_Timer device 65 loop took 6 seconds <0x2d328680>
01 03/13/16 11:09:47.647 LuaInterface::CallFunction_Timer device 66 loop took 5 seconds <0x2d528680>
01 03/13/16 11:10:55.041 LuaInterface::CallFunction_Timer device 65 loop took 6 seconds <0x2d328680>
01 03/13/16 11:10:56.579 LuaInterface::CallFunction_Timer device 66 loop took 5 seconds <0x2d528680>
01 03/13/16 11:12:02.767 LuaInterface::CallFunction_Timer device 66 loop took 5 seconds <0x2d528680>
01 03/13/16 11:12:04.299 LuaInterface::CallFunction_Timer device 65 loop took 6 seconds <0x2d328680>
01 03/13/16 11:13:11.769 LuaInterface::CallFunction_Timer device 66 loop took 5 seconds <0x2d528680>
01 03/13/16 11:13:12.164 LuaInterface::CallFunction_Timer device 65 loop took 6 seconds <0x2d328680>
01 03/13/16 11:14:18.628 LuaInterface::CallFunction_Timer device 66 loop took 5 seconds <0x2d528680>
01 03/13/16 11:14:22.050 LuaInterface::CallFunction_Timer device 65 loop took 6 seconds <0x2d328680>
01 03/13/16 11:15:27.677 LuaInterface::CallFunction_Timer device 66 loop took 5 seconds <0x2d528680>
01 03/13/16 11:15:32.134 LuaInterface::CallFunction_Timer device 65 loop took 6 seconds <0x2d328680>
01 03/13/16 11:16:36.620 LuaInterface::CallFunction_Timer device 66 loop took 5 seconds <0x2d528680>
01 03/13/16 11:16:40.119 LuaInterface::CallFunction_Timer device 65 loop took 6 seconds <0x2d328680>
01 03/13/16 11:17:44.669 LuaInterface::CallFunction_Timer device 66 loop took 5 seconds <0x2d528680>
01 03/13/16 11:17:48.274 LuaInterface::CallFunction_Timer device 65 loop took 6 seconds <0x2d328680>
01 03/13/16 11:18:51.950 LuaInterface::CallFunction_Timer device 66 loop took 5 seconds <0x2d528680>
01 03/13/16 11:18:57.148 LuaInterface::CallFunction_Timer device 65 loop took 6 seconds <0x2d328680>
01 03/13/16 11:19:57.613 LuaInterface::CallFunction_Timer device 66 loop took 5 seconds <0x2d528680>
01 03/13/16 11:20:05.156 LuaInterface::CallFunction_Timer device 65 loop took 6 seconds <0x2d328680>
01 03/13/16 11:21:03.977 LuaInterface::CallFunction_Timer device 66 loop took 5 seconds <0x2d528680>
01 03/13/16 11:21:12.136 LuaInterface::CallFunction_Timer device 65 loop took 6 seconds <0x2d328680>
01 03/13/16 11:22:12.559 LuaInterface::CallFunction_Timer device 66 loop took 5 seconds <0x2d528680>
01 03/13/16 11:22:19.300 LuaInterface::CallFunction_Timer device 65 loop took 6 seconds <0x2d328680>
01 03/13/16 11:23:19.679 LuaInterface::CallFunction_Timer device 66 loop took 5 seconds <0x2d528680>
01 03/13/16 11:23:27.270 LuaInterface::CallFunction_Timer device 65 loop took 6 seconds <0x2d328680>
amg0
March 15, 2016, 11:11am
2
[quote=“sebby, post:1, topic:191576”]I’ve been trying to troubleshoot some memory issues on my vera, and while i don’t think this is related, I wanted to make sure this plugin was working properly. when looking at my LupUPnP.log file and looking at only events with “01” status, i see this in my log after reloading Lua. that log entry stating the loop took X number of seconds always logs. is this normal or do i need to change something on my config?
01 03/13/16 11:23:27.270 LuaInterface::CallFunction_Timer device 65 loop took 6 seconds <0x2d328680> [/quote]
no issue, vera is complaining the function takes a little while ( but this is normal as it does several web service calls and is done asynchronously in a JOB ) so I would say nothing to worry here
sebby
March 15, 2016, 12:20pm
3
Thanks amg0! i figured it was nothing to worry about, but wanted to make sure. BTW, awesome plugin!
