Hi AK
I’ve had this error in my log for a long time and have never found the offending plugin. Is there a way I can trap for which plugin is causing the nil when it calls a wget?
2019-10-13 21:34:30.520 openLuup.http:: GET /data_request?id=lu_status2&output_format=json&DataVersion=27632241&Timeout=60&MinimumDelay=1500&=1571027652478 HTTP/1.1 tcp{client}: 0x560d31a0c1d8
2019-10-13 21:34:31.519 openLuup.http:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&=1571027652479 HTTP/1.1 tcp{client}: 0x560d3194df08
2019-10-13 21:34:31.623 openLuup.http:: request completed (1 bytes, 1 chunks, 103 ms) tcp{client}: 0x560d3194df08
2019-10-13 21:34:31.970 luup.io.incoming:: bytes received: 51, status: OK tcp{client}: 0x560d31a726e8
2019-10-13 21:34:36.971 luup.io.incoming:: bytes received: 51, status: OK tcp{client}: 0x560d31a726e8
2019-10-13 21:34:38.485 openLuup.context_switch:: ERROR: ./openLuup/client.lua:172: attempt to index local ‘request_URI’ (a nil value)
2019-10-13 21:34:38.485 luup.delay_callback:: function: 0x560d30a2dfb0 ERROR: ./openLuup/client.lua:172: attempt to index local ‘request_URI’ (a nil value)
2019-10-13 21:34:40.229 luup.variable_set:: 20012.urn:micasaverde-com:serviceId:ZWaveNetwork1.LastPollSuccess was: 1571027350 now: 1571027680 #hooks:0
2019-10-13 21:34:40.442 openLuup.http:: request completed (15212 bytes, 1 chunks, 9921 ms) tcp{client}: 0x560d31a0c1d8
2019-10-13 21:34:41.525 openLuup.http:: GET /data_request?id=lu_status2&output_format=json&DataVersion=27632243&Timeout=60&MinimumDelay=1500&_=1571027652480 HTTP/1.1 tcp{client}: 0x560d31a0c1d8
The two lines of error messages are in the middle of the log. Not sure if the log text will wrap correctly…
