Hello!
I have problems with my Vera and found out that there is this error in the LuaUPnP.log.
01 04/01/18 14:41:10.838 LuaInterface::LoadCode: [string “function scene_1()…”]:89: ‘end’ expected (to close ‘if’ at line 84) near ‘return’ <0x7703a000>
01 04/01/18 14:41:10.892 JobHandler_LuaUPnP::Run cannot start lua with code:
function scene_1()
However, I have no idea, where is code is. I wrote it some time agao
How can I find it? Is there a lua file where the startup code is?
Thanks, Stefan
In UI5: APPS → Develop Apps → Edit Startup Lua
Maybe something similar for UI7? That’s assuming that you can get to the UI to do something.
On UI7 look at the list of Scenes. It includes a scene ID. The one with number 1 looks to be the culprit. I heard that large bits of code in a scene can have issues to edit in UI7. Try ALTUI to fix the scene’s LUA code.
Cheers Rene
[quote=“jswim788, post:2, topic:198923”]In UI5: APPS → Develop Apps → Edit Startup Lua
Maybe something similar for UI7? That’s assuming that you can get to the UI to do something.[/quote]
This part is empty, I don’t have any code here
[quote=“reneboer, post:3, topic:198923”]Hi,
Cheers Rene[/quote]
In the scene with id:1 I’ve got 11 lines of code. What is ALTUI, I’ve never heard this…
ALTui is an alternative user interface to the Vera. See http://forum.micasaverde.com/index.php/board,78.0.html
It’s very nice with lots of great features. Check out the ‘read me first’ post.
Please post the 11 lines of code from scene #1. if there are calls to functions or other routines, the parser will reference the entire code block. So the 11 lines of obvious code may, in fact, be much larger, thus the reason that line #84 is tagged as the culprit. There are also some other techniques to help sort things out, but without knowing what the code does, its difficult to offer suggestions.
