Error getting status of: trigger/restart
I noticed that my PLTS’s had stopped working. I hadn’t made changes to them.
I opened the report and I get two errors:
Error getting status of: restart
This happens with all of my PLTS’s.
I did some restarts, browser refreshes, and reloads and they started working again. That was yesterday.
Just noticed that they’re not working again and I get the same issue.
Thoughts? Advice?
Running UI5.
PLTS/PLC are at 7.41
Report of one of my PLTS’s attached.
I’m still struggling with this. A few restarts and the PLTS will work for a while, bu will eventually begin failing. I haven’t made any edits to my PLTS’s and they’re all failing.
Is this UI5 or UI7 ?
A status report is needed to see more details.
Did you try to turn DEBUG on for the PLEGS.
I would start with the Debug output sent to it’s own file. (Using the PLEG LOG command.)
