Hi All,
I am getting the following errors for multiple devices, multiple times during the day. Any idea what can cause the error? I am trying to eliminate the errors but I have no idea where to look or what to do.
01 08/15/13 17:07:34.317 ZWJob_PollNode::ReceivedFrame job job#357 :pollnode #5 dev:22 (0x10c3ef8) N:5 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 5 got 11 <0x2b835680>
01 08/15/13 17:07:36.432 ZWJob_PollNode::ReceivedFrame job job#357 :pollnode #5 dev:22 (0x10c3ef8) N:5 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 5 got 12 <0x2b835680>
01 08/15/13 17:07:36.434 ZWJob_PollNode::ReceivedFrame job job#357 :pollnode #5 dev:22 (0x10c3ef8) N:5 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 5 got 12 <0x2b835680>
01 08/15/13 17:07:36.535 ZWJob_PollNode::ReceivedFrame job job#357 :pollnode #5 dev:22 (0x10c3ef8) N:5 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 5 got 12 <0x2b835680>
01 08/15/13 17:07:36.538 ZWJob_PollNode::ReceivedFrame job job#357 :pollnode #5 dev:22 (0x10c3ef8) N:5 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 5 got 12 <0x2b835680>
01 08/15/13 17:07:36.540 ZWJob_PollNode::ReceivedFrame job job#357 :pollnode #5 dev:22 (0x10c3ef8) N:5 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 5 got 12 <0x2b835680>
01 08/15/13 17:07:36.552 ZWJob_PollNode::ReceivedFrame job job#357 :pollnode #5 dev:22 (0x10c3ef8) N:5 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 5 got 12 <0x2b835680>
01 08/15/13 17:07:38.467 ZWJob_PollNode::ReceivedFrame job job#357 :pollnode #5 dev:22 (0x10c3ef8) N:5 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 5 got 10 <0x2b835680>
01 08/15/13 17:07:39.777 ZWJob_PollNode::ReceivedFrame job job#357 :pollnode #5 dev:22 (0x10c3ef8) N:5 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 5 got 8 <0x2b835680>
01 08/15/13 17:07:41.307 ZWJob_PollNode::ReceivedFrame job job#357 :pollnode #5 dev:22 (0x10c3ef8) N:5 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 5 got 11 <0x2b835680>
01 08/15/13 17:07:44.679 ZWJob_PollNode::ReceivedFrame job job#357 :pollnode #5 dev:22 (0x10c3ef8) N:5 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 5 got 12 <0x2b835680>
01 08/15/13 17:07:44.789 ZWJob_PollNode::ReceivedFrame job job#357 :pollnode #5 dev:22 (0x10c3ef8) N:5 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 5 got 12 <0x2b835680>
01 08/15/13 17:07:45.068 ZWJob_PollNode::ReceivedFrame job job#357 :pollnode #5 dev:22 (0x10c3ef8) N:5 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 5 got 12 <0x2b835680>
01 08/15/13 17:07:45.137 ZWJob_PollNode::ReceivedFrame job job#357 :pollnode #5 dev:22 (0x10c3ef8) N:5 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 5 got 12 <0x2b835680>
01 08/15/13 17:07:45.229 ZWJob_PollNode::ReceivedFrame job job#357 :pollnode #5 dev:22 (0x10c3ef8) N:5 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 5 got 12 <0x2b835680>
01 08/15/13 17:07:45.430 ZWJob_PollNode::ReceivedFrame job job#357 :pollnode #5 dev:22 (0x10c3ef8) N:5 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 5 got 12 <0x2b835680>
01 08/15/13 17:07:45.477 ZWJob_PollNode::ReceivedFrame job job#357 :pollnode #5 dev:22 (0x10c3ef8) N:5 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 5 got 12 <0x2b835680>
01 08/15/13 17:07:45.527 ZWJob_PollNode::ReceivedFrame job job#357 :pollnode #5 dev:22 (0x10c3ef8) N:5 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 5 got 12 <0x2b835680>
01 08/15/13 17:07:45.638 ZWJob_PollNode::ReceivedFrame job job#357 :pollnode #5 dev:22 (0x10c3ef8) N:5 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 5 got 12 <0x2b835680>
01 08/15/13 17:07:54.457 ZWJob_PollNode::ReceivedFrame job job#357 :pollnode #5 dev:22 (0x10c3ef8) N:5 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 5 got 12 <0x2b835680>
01 08/15/13 17:07:54.527 ZWJob_PollNode::ReceivedFrame job job#357 :pollnode #5 dev:22 (0x10c3ef8) N:5 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 5 got 12 <0x2b835680>
01 08/15/13 17:07:54.677 ZWJob_PollNode::ReceivedFrame job job#357 :pollnode #5 dev:22 (0x10c3ef8) N:5 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 5 got 12 <0x2b835680>
01 08/15/13 17:07:54.727 ZWJob_PollNode::ReceivedFrame job job#357 :pollnode #5 dev:22 (0x10c3ef8) N:5 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 5 got 12 <0x2b835680>
01 08/15/13 17:07:54.837 ZWJob_PollNode::ReceivedFrame job job#357 :pollnode #5 dev:22 (0x10c3ef8) N:5 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 5 got 12 <0x2b835680>
01 08/15/13 17:07:55.027 ZWJob_PollNode::ReceivedFrame job job#357 :pollnode #5 dev:22 (0x10c3ef8) N:5 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 5 got 12 <0x2b835680>
01 08/15/13 17:07:55.137 ZWJob_PollNode::ReceivedFrame job job#357 :pollnode #5 dev:22 (0x10c3ef8) N:5 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 5 got 12 <0x2b835680>
01 08/15/13 17:07:55.227 ZWJob_PollNode::ReceivedFrame job job#357 :pollnode #5 dev:22 (0x10c3ef8) N:5 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 5 got 12 <0x2b835680>
01 08/15/13 17:07:55.337 ZWJob_PollNode::ReceivedFrame job job#357 :pollnode #5 dev:22 (0x10c3ef8) N:5 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 5 got 12 <0x2b835680>
01 08/15/13 17:07:55.447 ZWJob_PollNode::ReceivedFrame job job#357 :pollnode #5 dev:22 (0x10c3ef8) N:5 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 5 got 12 <0x2b835680>
01 08/15/13 17:12:36.386 ZWJob_PollNode::ReceivedFrame job job#367 :pollnode #7 dev:18 (0x11163f0) N:7 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 7 got 12 <0x2b835680>
01 08/15/13 17:12:36.396 ZWJob_PollNode::ReceivedFrame job job#367 :pollnode #7 dev:18 (0x11163f0) N:7 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 7 got 12 <0x2b835680>
01 08/15/13 17:12:36.612 ZWJob_PollNode::ReceivedFrame job job#367 :pollnode #7 dev:18 (0x11163f0) N:7 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 7 got 12 <0x2b835680>
01 08/15/13 17:12:36.614 ZWJob_PollNode::ReceivedFrame job job#367 :pollnode #7 dev:18 (0x11163f0) N:7 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 7 got 12 <0x2b835680>
01 08/15/13 17:12:36.616 ZWJob_PollNode::ReceivedFrame job job#367 :pollnode #7 dev:18 (0x11163f0) N:7 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 7 got 12 <0x2b835680>
01 08/15/13 17:12:36.628 ZWJob_PollNode::ReceivedFrame job job#367 :pollnode #7 dev:18 (0x11163f0) N:7 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 7 got 12 <0x2b835680>
01 08/15/13 17:12:36.631 ZWJob_PollNode::ReceivedFrame job job#367 :pollnode #7 dev:18 (0x11163f0) N:7 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 7 got 12 <0x2b835680>
01 08/15/13 17:12:36.633 ZWJob_PollNode::ReceivedFrame job job#367 :pollnode #7 dev:18 (0x11163f0) N:7 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 7 got 12 <0x2b835680>
01 08/15/13 17:12:36.635 ZWJob_PollNode::ReceivedFrame job job#367 :pollnode #7 dev:18 (0x11163f0) N:7 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 7 got 12 <0x2b835680>
01 08/15/13 17:13:44.537 ZWJob_PollNode::ReceivedFrame job job#369 :pollnode #9 dev:31 (0x10c1668) N:9 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 9 got 12 <0x2b835680>
01 08/15/13 17:13:44.612 ZWJob_PollNode::ReceivedFrame job job#369 :pollnode #9 dev:31 (0x10c1668) N:9 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 9 got 12 <0x2b835680>
01 08/15/13 17:13:45.171 ZWJob_PollNode::ReceivedFrame job job#369 :pollnode #9 dev:31 (0x10c1668) N:9 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 9 got 12 <0x2b835680>
01 08/15/13 17:13:45.227 ZWJob_PollNode::ReceivedFrame job job#369 :pollnode #9 dev:31 (0x10c1668) N:9 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 9 got 12 <0x2b835680>
01 08/15/13 17:13:45.308 ZWJob_PollNode::ReceivedFrame job job#369 :pollnode #9 dev:31 (0x10c1668) N:9 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 9 got 12 <0x2b835680>
01 08/15/13 17:13:45.488 ZWJob_PollNode::ReceivedFrame job job#369 :pollnode #9 dev:31 (0x10c1668) N:9 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 9 got 12 <0x2b835680>
01 08/15/13 17:13:45.607 ZWJob_PollNode::ReceivedFrame job job#369 :pollnode #9 dev:31 (0x10c1668) N:9 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 9 got 12 <0x2b835680>
01 08/15/13 17:13:45.728 ZWJob_PollNode::ReceivedFrame job job#369 :pollnode #9 dev:31 (0x10c1668) N:9 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 9 got 12 <0x2b835680>
01 08/15/13 17:13:46.398 ZWJob_PollNode::ReceivedFrame job job#369 :pollnode #9 dev:31 (0x10c1668) N:9 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 9 got 11 <0x2b835680>
01 08/15/13 17:13:54.547 ZWJob_PollNode::ReceivedFrame job job#369 :pollnode #9 dev:31 (0x10c1668) N:9 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 9 got 12 <0x2b835680>
01 08/15/13 17:13:55.037 ZWJob_PollNode::ReceivedFrame job job#369 :pollnode #9 dev:31 (0x10c1668) N:9 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 9 got 12 <0x2b835680>
01 08/15/13 17:13:55.167 ZWJob_PollNode::ReceivedFrame job job#369 :pollnode #9 dev:31 (0x10c1668) N:9 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 9 got 12 <0x2b835680>
01 08/15/13 17:13:55.317 ZWJob_PollNode::ReceivedFrame job job#369 :pollnode #9 dev:31 (0x10c1668) N:9 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 9 got 12 <0x2b835680>
01 08/15/13 17:13:55.477 ZWJob_PollNode::ReceivedFrame job job#369 :pollnode #9 dev:31 (0x10c1668) N:9 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 9 got 12 <0x2b835680>
01 08/15/13 17:13:55.547 ZWJob_PollNode::ReceivedFrame job job#369 :pollnode #9 dev:31 (0x10c1668) N:9 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 9 got 12 <0x2b835680>
01 08/15/13 17:13:55.717 ZWJob_PollNode::ReceivedFrame job job#369 :pollnode #9 dev:31 (0x10c1668) N:9 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 9 got 12 <0x2b835680>
01 08/15/13 17:14:04.527 ZWJob_PollNode::ReceivedFrame job job#369 :pollnode #9 dev:31 (0x10c1668) N:9 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 9 got 12 <0x2b835680>
01 08/15/13 17:14:04.598 ZWJob_PollNode::ReceivedFrame job job#369 :pollnode #9 dev:31 (0x10c1668) N:9 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 9 got 12 <0x2b835680>
01 08/15/13 17:14:04.817 ZWJob_PollNode::ReceivedFrame job job#369 :pollnode #9 dev:31 (0x10c1668) N:9 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 9 got 12 <0x2b835680>
01 08/15/13 17:14:04.857 ZWJob_PollNode::ReceivedFrame job job#369 :pollnode #9 dev:31 (0x10c1668) N:9 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 9 got 12 <0x2b835680>
01 08/15/13 17:14:04.917 ZWJob_PollNode::ReceivedFrame job job#369 :pollnode #9 dev:31 (0x10c1668) N:9 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 9 got 12 <0x2b835680>
01 08/15/13 17:14:05.078 ZWJob_PollNode::ReceivedFrame job job#369 :pollnode #9 dev:31 (0x10c1668) N:9 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 9 got 12 <0x2b835680>
01 08/15/13 17:14:05.307 ZWJob_PollNode::ReceivedFrame job job#369 :pollnode #9 dev:31 (0x10c1668) N:9 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 9 got 12 <0x2b835680>
01 08/15/13 17:14:05.459 ZWJob_PollNode::ReceivedFrame job job#369 :pollnode #9 dev:31 (0x10c1668) N:9 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 9 got 12 <0x2b835680>
01 08/15/13 17:14:05.588 ZWJob_PollNode::ReceivedFrame job job#369 :pollnode #9 dev:31 (0x10c1668) N:9 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 9 got 12 <0x2b835680>
01 08/15/13 17:14:05.677 ZWJob_PollNode::ReceivedFrame job job#369 :pollnode #9 dev:31 (0x10c1668) N:9 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 9 got 12 <0x2b835680>
01 08/15/13 17:14:34.838 ZWJob_PollNode::ReceivedFrame job job#370 :pollnode #10 dev:38 (0x111da60) N:10 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 10 got 12 <0x2b835680>
01 08/15/13 17:14:35.197 ZWJob_PollNode::ReceivedFrame job job#370 :pollnode #10 dev:38 (0x111da60) N:10 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 10 got 12 <0x2b835680>
01 08/15/13 17:14:35.548 ZWJob_PollNode::ReceivedFrame job job#370 :pollnode #10 dev:38 (0x111da60) N:10 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 10 got 12 <0x2b835680>
01 08/15/13 17:14:35.637 ZWJob_PollNode::ReceivedFrame job job#370 :pollnode #10 dev:38 (0x111da60) N:10 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 10 got 12 <0x2b835680>
01 08/15/13 17:14:35.727 ZWJob_PollNode::ReceivedFrame job job#370 :pollnode #10 dev:38 (0x111da60) N:10 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 10 got 12 <0x2b835680>
01 08/15/13 17:14:35.837 ZWJob_PollNode::ReceivedFrame job job#370 :pollnode #10 dev:38 (0x111da60) N:10 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 10 got 12 <0x2b835680>
01 08/15/13 17:14:35.927 ZWJob_PollNode::ReceivedFrame job job#370 :pollnode #10 dev:38 (0x111da60) N:10 P:100 S:5 got FUNC_ID_APPLICATION_COMMAND_HANDLER node info expected 10 got 12 <0x2b835680>
01
