Enerwave ZWN-RSM1S switch
Anyone out here who has successfully used this single pole switch? [url=http://www.amazon.com/Enerwave-ZWN-RSM1S-Z-Wave-Single-Function/dp/B00JW0G1A2/ref=sr_1_1?ie=UTF8&qid=1412521269&sr=8-1&keywords=zwn-rsm1s]http://www.amazon.com/Enerwave-ZWN-RSM1S-Z-Wave-Single-Function/dp/B00JW0G1A2/ref=sr_1_1?ie=UTF8&qid=1412521269&sr=8-1&keywords=zwn-rsm1s[/url]
I have it connected according to their wiring diagram 2 but cant seem to turn the lights on. I can hear relay clicking when switch is turned on or off manually or from the controller.
I have used their dual switch to control two lights out of dual switch successfully. cant seem to figure this one out. other couple reviews suggested same problem so just wondering if its their alternative way to wire it.
Thanks.
Have you tried a momentary switch?
Also If memory serves correct you have to use the NC NO for the load.
Did anyone figure out the correct wiring diagram for this?
I emailed the manufacturer and received a revised wiring diagram. Essentially it connects the com and NO wires.
