i have a Vera Plus and some lamps installed via Aeon Labs smart switch 6 wall plugs. After the could not detect warning and turning
the plus on manually the plugs work again an the no detect warning is over but now these plugs show no energy metering.
So what can i do to get these working again?
So no answers on my question. So new try with different approach. How can i put on or of (Aeotec Smart Switch 6)
the tracking of how much electricity i use in a Vera Plus?
I got mine working
see You tube video on procedure
configuring Aeotec smart energy dimmer Part 1 and part 2
You tube energy settings https://www.youtube.com/watch?v=d_FanvsDCr4
RVF
However I cant find out how to set the range of the Tab >> Energy >> Home Use as I get negative values
I need to set the range and parameters on the cost and Kwh
can not find any way to make adjustments.
Any ideas ?
Thanks RVF
