It doesnt have free plan and 1 euro per feed doesn’t look appealing
It is not reactive, you need to refresh the page every time you want to see real results
It so so slow when you refresh
The app is a joke
Is there something better than that?
Or, as the alternative I can make my own, but then I would need to see if there is an interest to make it out
[quote=“ipstas”]datamine I don’t like even more, it is a so not a good idea to have data in a db on a very limited vera.
Actually, let me put it simply. It is stupid.
No reactivity, limited storage, weak hw, it is a nightmare
And there is no need to keep that data on vera, set the feed, push it out, enjoy the view[/quote]
Agree, datamine trash?s my Vera edge. Are you working on an alternative ?
[quote=“ipstas, post:1, topic:200488”]I am currently using emoncms and I don’t like it.
The app is a joke
Or, as the alternative I can make my own, but then I would need to see if there is an interest to make it out[/quote]
You can download econcms for free. It runs on a number of platforms and can be customized to whatever degree you wish.
I’d like to see first if there is an interest. I can pick it up as a sideproject, but too lazy just to do it for myself only. I want few people on board from the beginning as early adopters.
I ll check that, however I was really hoping to offload anything extra from vera, vera is really limited hw. And then I would need another machine to run grafana
Emonscms is great in offloading and setting a feed is really simple. But I dont like the rest of it.
i’ll signup. been looking for a good choice for years, but all have compromises. im still using the ergy plugin. (slow and no access to raw data files)
I’d like to see first if there is an interest. I can pick it up as a sideproject, but too lazy just to do it for myself only. I want few people on board from the beginning as early adopters.[/quote]
Just checking if anybody else would want to see it? I probably will take it as a side project anyway, but some early adopters would be really encouraging.
[quote=“ipstas, post:10, topic:200488”]I ll check that, however I was really hoping to offload anything extra from vera, vera is really limited hw. And then I would need another machine to run grafana
Emonscms is great in offloading and setting a feed is really simple. But I dont like the rest of it.[/quote]
I built my own small solution for monitoring the energy consumption of my well pump and fence lights and it was not that difficult.
I push the logs from vera to a raspberry pi and parse them to get the info I need and store that in a mysql database. Then I use c3js to create the graphs. Attached is the graph for the well pump. In orange is consumption in watts. In blue is a counter that starts when the pump starts and counts for 6 minutes. I have a scene that checks that the pump is off when the counter finishes and if sends an email.
I keep all the logs from when I started this, so if I want to add another device to the graphs, I can reprocess all files.
Works really simple, you just need a lua file (provided as well), change it to your liking with devices id and serviceId, add to your Luup files. Edit your Startup Lua to include
[font=courier]monitcode = require(“Moniton”)[/font]
As soon as you have started pushing data you can select what feed is going to be used for linear or gauge and it comes to your dashboard
As soon as you have started pushing data you can select what feed is going to be used for linear or gauge and it comes to your dashboard[/quote]
Huh,?
Are you still looking into building a replacement or a power usage plugin ipstas?
