I’ve been trying to log onto my Vera Edge via SSH and telnet (both resulting in Connection Refused on port 22) to do some LuuP debugging. I tried toggling the “Secure your Vera” checkbox which as I understand, allows tech support remote access…
Anyone have any recommendations?[/quote]
Strange it works fine out of the box with my Edge.
I use Putty, connect with protocol SSH on port 22 to the IP of your Edge.
If that doesn’t work then there must be “something in between” that doesn’t allow you to do this.
Does the Web interface work fine? No issues there?
