I have installed a series of Aspire RF Z-wave wall receptacles throughout my house. The pairing with Vera and remote on/off all seem to work fine.
The only thing I could not get it to work is to enable its Load Sensing feature (so that when I manually switch on a light attached to the z-wave outlet, it will turn on the electricity).
I am guessing I need to put in some parameter values in UI5. Please kindly let me know if you know what the values are.
Ironically I have spent the past few weeks figuring out how to disable the load sense feature on Intermatic CA3500s… :o… CA3500’s come out of the box with load sense enabled. One guy was selling these for 6 for $99 on eBay but he may have run out of stock. A lot less expensive that Cooper.
In my journey I did learn about something called parameter 29 which on some receptacles is the parameter to enable/disable load sense. Not sure if its relevant to Cooper but to try is easy enough. Search for load sense and parameter 29 and you’ll find how its done…
