EMONCMS
Hi to all,
i want to do energy monitoring with vera edge , and have solar pv home production.
I think the best system for that purpose is emoncms .
Then, i’m searching for any possible help to find a vera plugin for emoncms .
I’m using rfxcom with owl cm 180 clamps, and i would be also pleased if someone could help me to set the zero point by vera edge / rfxcom data reception tuning.
The default of these clamps is the accuracy under 100w, and fixing the zero point is a good solution for enhancing this feature. This can be done by a simple calculation in the device / plugin (if there is any feature for this calculation in Vera software ) .
Any help welcome, and cheers from Aix en Provence ! :wink:
