I am currently building a new house and making a project for electricity. I want to use z-wave for automation!
Of course i want to automate everything withch is possible, lights, power supply, security, window blinds, multimedia…
So i have qustion below :
How is make batter to compose the electricity network:
- Each floor to have own board with all z-wave devices such as dimmers and relays. The house is quite big (4 floors, more then 100 sq.m each. With sure i should to put some main powered devices between floor to repeat the signal. All modules should be wired directly to the floor board.
or - To place each modules under the switches and power socets in the rooms. In that case i should put neutral everywhere if i want to use relays.
Could you please be so kind and recommend me witch is a better option.
