Is it possible to edit the home automation controls in SQ designer? Either add new ones or edit with themes? Or else edit the size or spacing between description and readout such as on the temp/hvac/thermostat settings?
i guess it could be done just like the regular icons!
get the PNG file you want, drag in to the one you want to change!
done!
