[quote=“integlikewhoa, post:52, topic:187123”]I guess I’m the only one seeing a problem with closing off several vents at a time let along all up stairs or all down stairs vents.
I have a 4 zone system installed by myself. Alot of calculation goes into setting up the system along with extra components like Bypass dampers, and temp sensors in the plenum. Further testing is done after with a static pressure check to make sure inlet and exhaust duct and gill sizing was done right and no restrictions in the system.
If you close off several vents you disrupt the air flow. Pressure builds on the outlet side and airflow slows down threw the coil and heater. When pressure builds you loose efficiency, cause damage to ducts and leaks. When the air slows down the coil starts to freeze, if your heating the heater gets too hot. They are sized to have a certain CFM of air across them.
A zone system has a bypass damper to keep the air moving by opening when the pressure builds and reusing the air again, never slowing it down threw the unit. All zone systems also come with a sensor to monitor temp coming out of the unit to make sure it’s not getting to high or low as a safety.
The other thing is the system gets noisy when you try to close off half the ducts. In the open ducts air flow speeds up creating noise in the rooms.
For the guys that are trying to buy like 8-10 of these I would suggest you look into how the a/c works a bit more your gonna have problems. For the guys that have one unused room that your closing off, you should see no problem.[/quote]
I for one will be installing a bypass damper (as discussed earlier in this thread) even if I don’t need it which in my case, I don’t think I do. Since it’s a very simple & inexpensive install, at least for me and it will eliminate any built up pressure, I am going to put one in. That said, I already have a handful of vents closed off and those vents will be replaced with the z-wave ones. I also won’t be closing off all vents at once upstairs or down stairs at any given time. My master bedroom and master batch uses a vent that is larger then they supply and I have a few vents downstairs that also are of a size that Econet doesn’t currently support. For my master bedroom, I may put a 24v damper in the duct and install a Z-Wave outlet in the attic to control that vent.
That said, your points are valid and if you are closing off a lot of vents at one time, the bypass damper is a good thing to install. It also has the upside of making the system more efficient by further cooling or heating the air due to recirculating it through the system. I had a long conversation about this scenario with a good friend who is an AC installer and he looked at my system and while we agree that it’s probably not needed in my case, it will only improve things and help me accomplish my goal of making my system much more efficient without having to spend thousands on redoing everything.
