Everything looks right, I have all my sensors and thermostat showing up. However, when I enter a temp to adjust my heat, the wheel starts to spin but I cannot adjust the temperature either up or down. The temperature enters, but the actual thermostat never adjusts
I have the same issue - running UI7, with version 1.3 of the plugin. I can set modes (cooling, heating, auto), but setting temp ranges or temperatures does nothing except return a “command failed”. Tried re-installing, rebooting, but it doesn’t seem to help.
While I can use the ecobee app, it’d be nice to hook it into Vera. Any help would be appreciated!
