It’s NOT Z-Wave, but speaks 802.11 b/g and (optionally) Zigbee. I figured I’d pass this along solely as a curiosity, as I remain uncertain about Vera’s ability to interoperate with such a device … except obviously Vera “speaks” Wi-Fi. Can she interpret Zigbee, as well? (I’ve asked elsewhere in the Forum.)
Anyway, the ecoBee at least has “cuteness” and “ambition” going for it!
“So, has anyone integrated an Ecobee with Vera yet?”
Probably not and here’s why. I have not one but two Ecobees and have had quite a series of emails with their customer “support” about this issue Suffice it to say that Ecobee is mega-paranoid about their protocol. All communication between the thermostat and their website is encrypted and they absolutely refuse to make any sort of API available to customers or even provide a UI that allows local communication.
So in order to talk to my thermostat that’s 30 feet away, I have to connect to a web site 1200 miles away, in a different country.
It might make an interesting cryptology project but I honestly think the easiest solution may simply be to throw out their web server chip and replace it with a simple Netburner SB-70 or the like.
I’d love to hear from someone who’s gotten around this particular irritation.
Yes, it’s quite frustrating. There might be some promise in looking at the Android Ecobee app. It should be possible to figure out how to talk to Ecobee’s servers yourself, but AFAIK, no one has cracked the encryption yet to talk directly to the thermostat. Maybe we can interest Anonymous in this project ???
Joshua Stein made his own start on reverse engineering the Ecobee API and he’s succesfully developed a plugin for SiriProxy that enables him to voice control his Ecobee thermostat using an iPhone 4S. Joshua Stein’s plugin uses the JSON API that he found in Ecobee’s Android app. In a posting on the Ecobee users group Joshua provided a link to the pretty-print of the JSON data available through the API:
That is the output of the /ecobee/thermostat call, passing the thermostat id found from /ecobee/summary. Joshua’s code for interacting with ecobee’s API can be found at:
Yes, this is an impressive feat of software engineering. Unfortunately, all it lets you to is talk directly to the same web server that I don’t want to talk to in the first place. I want to be able to communicate directly from my PC to my thermostat on the same LAN without making a multi-thousand mile detour through Canada.
