I have a Horstmann Zwave thermostat in my vera syste and am working out the best way to control it. At the moment I use Multistring variables to store and adjust the times of the day and the temperatures I want and send them to the stat using Lua coding. So I have time 4 “timezones” that start at 7.30 9.30 17.30 and 22.30 and 4 corresponding temperatures for each time. It all works well, and I can also obviously adjust the stat manually or via Vera as well at any time. As the icing on the cake though, I would like to be able to easily adjust the temperatures for each time period from Imperihome which I use as my normal interface. With the Multistring I have to go into the device control in VERA to do it.
So, this is my question (after a lot of waffle!) can I create 4 “dummy” thermostats (one for each time zone) that appear on the Vera exactly as the Hortsmann does, but that aren’t actually paired to anything? If I could do that, I can adjust the set temperature easily in Imperhome or Vera and then just read the value and send it to my real thermostat at the appropriate time. I have seen the virtual thermostat plugin but that has lots of controls that I won’t use. I just want a simple temperature display with up and down setting buttons, that Imperihome can interact with.
Any suggestions gratefully received.
