Dual Band Insteon devices giving unable to get any information on node
I am using a veralite and I am configuring my insteon devices in the veralite without any problem except for the insteon dual band devices. Each of these devices have a permanent red bar " unable to get any information on node" What am I doing wrong?
There are a few things I would check.
  1. Which power phase are the devices on? If the dual band devices are on a different phase than the PLM, and the PLM is too far to talk to them wirelessly, then you will have issues.
  2. Do you have links set up? If you don’t have links between the PLM and the other devices, the PLM will ignore any messages from the other devices. If you tried to use the Vera to do the linking, I wouldn’t rely on it. Link it manually. I am 99% sure that the Vera can’t handle I2C linking, and probably ignores error codes, so the only way to be sure is to manually link.
  3. Don’t use the native Insteon support on the Vera. It is marginal at best.
Hi FBA,
As you can see I am new in this technology. You were asking do you have links setup? How do you set those links?
You do recommend an alternative to the native Insteon support on the vera, what alternative is there?
Thanks again
The alternative is called Altsteon. Links need to be done via the plm and the insteon devices. You might want to read up on how insteon works and how to add the links.
  • Garrett
