I am an alarm installer and have used DSC exclusively for 25 years. I have hooked up an EVL-3CG and it works fine. The Vera Lite is working but only the stay bullet button on the dashboard work. The other three do nothing. I have to press the wrench to get to next screen and then can use. using UI5 and same with UI6. I have disarm in the parameters. Any suggestion or cheat sheet for these parameters in advanced setup
