Hey strangely or anyone else with the ptk5507. I was wondering how well the keypad does programming the system? Right now I use the DLS and that seems pretty easy. But i really like the touchscreen.
It’s better, but then again I haven’t programmed a whole system with one, I’ve just applied a few tweaks here and there. If you are used to the DLS software then it’s still probably quicker and easier!
I really like the keypad since doing things like bypassing zones and using PGMs is very intuitive.
My only gripe with it, is that it has a really nice clock mode, but once the screen goes off, you have to reactivate it again from a sub menu, and I want it to stay there all the time!
@strangely they have released a firmware update. it is not available publicly but PM me if you can not download it. Unsure of what is fixes, nothing listed
If its 1.04 then I have a copy of it I’ve not loaded yet. However I don’t think it fixes the clock problem anyway, but I guess I should give it a try tomorrow!
If you have anything later than 1.04? Then yes I will PM you.
Just checked, the current version is 1.04.
[quote=“strangely, post:2, topic:172914”]It’s better, but then again I haven’t programmed a whole system with one, I’ve just applied a few tweaks here and there. If you are used to the DLS software then it’s still probably quicker and easier!
My only gripe with it, is that it has a really nice clock mode, but once the screen goes off, you have to reactivate it again from a sub menu, and I want it to stay there all the time![/quote]
Thanks for the info man! I plan on getting one soon and maybe I’ll ditch having to bring my computer to the panel all the time to reprogram things.
Do you have either a 2DS or IT100 connected to your Panel?
I do have the 2DS connected to the Panel.
It is possible to send programming commands to the panel from the Eyez-on website, although I’ve never done it!
does anyone have the latest firmware for ptk5507
What is the latest firmware version?
