DSC plugin - confused!
Can someone please tell me which instructions I should be following to get my DSC alarm panel with 2DS interface working? I’ve searched and have come across different instructions, some of which are conflicting or a bit incomplete.
I’m running a Vera 1 with UI4.
Thanks.
I would suggest holding off for a couple of days or so, as there’s a new version about to get pushed to the app store.
I also need to make some mods to better support the UI4 and 2DS combination. The version I released last night doesn’t have these (yet) so it’ll work find on UI5, but likely cause issues in UI4.
I plan on borrowing some code from @futzle’s Plugin to [attempt to] stave off a Lua concurrency problem in UI4 that would hit if you used the latest version.
Anyhow, it’ll likely be the weekend before I can get to that, as the plate is rather full right now.
Sounds good … and thank you both.
-GT
