Not sure if this will be of use to others, but as I have the Panic button set to trigger the siren, after a bit of digging I found that this code does the same thing.
local dev = 344
luup.call_action("urn:micasaverde-com:serviceId:DSCAlarmPanel1",
"SendCommand",
{Command = "060", Data="3"}, dev)
