I am on u15
I can use the code I setup to Poll open or closed ZONES … eventually sends a message to my phone via a PUSHOVER message… this works. However I suspect it is now talking to the the security sensors that are showing up on the system , and showing if tripped or not… That code is quite long winded below … The code directly below does not activate or talk to the alarm … this trying to “talk to the panel”
The code sent to BYPASS a ZONE… (doesn’t work anymore)
luup.call_action(“urn:micasaverde-com:serviceId:DSCAlarmPanel1”,
“SendCommand”,
{Command = “070”, Data=“*”}, 80)
“SendCommand”,
{Command = “070”, Data=“1”}, 80)
“SendCommand”,
“SendCommand”,
{Command = “070”, Data=“0”}, 80)
“SendCommand”,
{Command = “070”, Data=“#”}, 80)
Code to POLL zones
local Z1 = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”, “Tripped”, 81)
local Z2 = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”, “Tripped”, 82)
local Z3 = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”, “Tripped”, 83)
local Z4 = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”, “Tripped”, 84)
local Z5 = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”, “Tripped”, 85)
local Z6 = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”, “Tripped”, 88)
local Z7 = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”, “Tripped”, 100)
local Z8 = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”, “Tripped”, 89)
local Z9 = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”, “Tripped”, 101)
local Z10 = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”, “Tripped”, 90)
local Z11 = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”, “Tripped”, 102)
local Z12 = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”, “Tripped”, 91)
local Z13 = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”, “Tripped”, 103)
local Z14 = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”, “Tripped”, 104)
local Z15 = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”, “Tripped”, 105)
local Z16 = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”, “Tripped”, 92)
local Z17 = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”, “Tripped”, 93)
local Z18 = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”, “Tripped”, 106)
local Z19 = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”, “Tripped”, 107)
local Z20 = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”, “Tripped”, 108)
local Z21 = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”, “Tripped”, 109)
local Z22 = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”, “Tripped”, 110)
local Z23 = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”, “Tripped”, 94)
local Z24 = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”, “Tripped”, 95)
local Z25 = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”, “Tripped”, 96)
local Z26 = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”, “Tripped”, 97)
local Z27 = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”, “Tripped”, 98)
local Z28 = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”, “Tripped”, 99)
local Z29 = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”, “Tripped”, 111)
local Z30 = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”, “Tripped”, 126)
local Z31 = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”, “Tripped”, 122)
local Z32 = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”, “Tripped”, 123)
local msg
local trips = ‘’
if tonumber(Z1) == 1 then
trips = trips … “SMS Arm\n”
if tonumber(Z2) == 1 then
trips = trips … “Guest Passage\n”
if tonumber(Z3) == 1 then
trips = trips … “Passage PIR\n”
if tonumber(Z4) == 1 then
trips = trips … “Laundry PIR\n”
if tonumber(Z5) == 1 then
trips = trips … “Kitchen VX\n”
if tonumber(Z6) == 1 then
trips = trips … “Front Door\n”
if tonumber(Z7) == 1 then
trips = trips … “Kitchen PIR\n”
if tonumber(Z8) == 1 then
trips = trips … “Remote Arm\n”
if tonumber(Z9) == 1 then
trips = trips … “Fountain VX\n”
if tonumber(Z10) == 1 then
trips = trips … “Lounge Kitchen\n”
if tonumber(Z11) == 1 then
trips = trips … “Lounge PIR\n”
if tonumber(Z12) == 1 then
trips = trips … “TV Study\n”
if tonumber(Z13) == 1 then
trips = trips … “Pool VX\n”
if tonumber(Z14) == 1 then
trips = trips … “TV PIR\n”
if tonumber(Z15) == 1 then
trips = trips … “Club Road Beam\n”
if tonumber(Z16) == 1 then
trips = trips … “Panic Zone\n”
if tonumber(Z17) == 1 then
trips = trips … “Stair Window\n”
if tonumber(Z18) == 1 then
trips = trips … “Landing PIR\n”
if tonumber(Z19) == 1 then
trips = trips … “Front Beam\n”
if tonumber(Z20) == 1 then
trips = trips … “Study Beam\n”
if tonumber(Z21) == 1 then
trips = trips … “Balcony VX\n”
if tonumber(Z22) == 1 then
trips = trips … “Front Wall Beam\n”
if tonumber(Z23) == 1 then
trips = trips … “Upstairs Window\n”
if tonumber(Z24) == 1 then
trips = trips … “Laundry Garage\n”
if tonumber(Z25) == 1 then
trips = trips … “Kate’s Room\n”
if tonumber(Z26) == 1 then
trips = trips … “Emma’s Room\n”
if tonumber(Z27) == 1 then
trips = trips … “Main Bedroom\n”
if tonumber(Z28) == 1 then
trips = trips … “Ensuite\n”
if tonumber(Z29) == 1 then
trips = trips … “D/Door VX\n”
if tonumber(Z30) == 1 then
trips = trips … “Z30 Unknown\n”
if tonumber(Z31) == 1 then
trips = trips … “Garage Door\n”
if tonumber(Z32) == 1 then
trips = trips … “Gate\n”
if string.len(trips) > 0 then
msg =“” … trips
else
msg = "No zones are open. "
luup.call_action(“urn:upnp-org:serviceId:IOSPush1”, “SendPushOverNotification”,{ Title= “Open Zone Status”, Message=msg, Priority=1, URL=“”, URLTitle=“”, Sound=“intermission”}, 121)
