DSC Alarm Issue
Good Evening all
I have just installed my DSC alarm and got it all working within vera and homewave BUT it doesnt ask for the pin to disarm the system within homewave, Within settings of the icon i have selected PIN but it doesnt ask for it to disarm the system.
Also is it possible to have the icon change from arm and disarm just like you can change with a light switch.
Thank you for help in advance
Rich
Hi Rich,
When you select PIN for the control, this refers to HomeWave’s PIN which you can set in the app’s settings screen. If you didn’t set a PIN, HomeWave will not ask for it.
If your DSC alarm requires a PIN to disarm, you can specify that PIN in the properties for the alarm control element in HomeWave.
[quote=“intveltr, post:2, topic:183047”]Hi Rich,
If your DSC alarm requires a PIN to disarm, you can specify that PIN in the properties for the alarm control element in HomeWave.[/quote]
Hi
Yes my DSC Alarm does have a PIN but i done that within the element of HomeWave but still doesnt prompt for it when goto disarm.
[quote=“Rich1983, post:3, topic:183047”][quote=“intveltr, post:2, topic:183047”]Hi Rich,
Hi
Yes my DSC Alarm does have a PIN but i done that within the element of HomeWave but still doesnt prompt for it when goto disarm.[/quote]
UPDATE:
I see if you put the PIN in within the element it allows you to disarm the system BUT is it possible for it to prompt you for the PIN to disarm the system?
[quote=“Rich1983, post:4, topic:183047”][quote=“Rich1983, post:3, topic:183047”][quote=“intveltr, post:2, topic:183047”]Hi Rich,
Hi
UPDATE:
I see if you put the PIN in within the element it allows you to disarm the system BUT is it possible for it to prompt you for the PIN to disarm the system?[/quote]
Is it possible to just displace the ENTER PIN as i have more than one pin for alarm system
The app cannot cope with multiple PINs for your alarm system, or prompt you to enter the alarm system PIN.
You can protect the control using HomeWave’s PIN, by setting the control to “PIN”. You also need to set the PIN in Settings->general before the control will ask for a PIN when used.
[quote=“intveltr”]The app cannot cope with multiple PINs for your alarm system, or prompt you to enter the alarm system PIN.
You can protect the control using HomeWave’s PIN, by setting the control to “PIN”. You also need to set the PIN in Settings->general before the control will ask for a PIN when used.[/quote]
Is this something for future to allow?
