DSC alarm control in 1.41 [solved]
Great thanks to the developer for introducing the alarm control!
A quick question: I can’t figue out how to Arm Away my DSC system with this version. Selecting Arm initiates the exit delay, but always ends up putting the alarm in Stay mode. Selecting Stay works as intended.
Any suggestions?
How would you normally arm the system from the Vera UI?
By hitting the Arm button (screenshots below). I had a scene setup that would do that in the previous version of HomeWave.
Does anyone using a different type of alarm panel experience the same issue?
WhiteBeard,
I’m not sure how your alarm is set up but on mine if I do not use one of the exit delay doors after setting the alarm to arm away it automatically arms with stay mode.
Brian
@Brian: hmmm, good point! I’ll test it tonight. Thanks.
@Brian: that was it! Thanks for the tip.
