This past yearI changed alarm companies and installed a ipDatatel BAT/CDMA Transceiver to connect to the monitoring station. I have a VeraEdge controller which operates some keyless dead locks. I pointed the Vera to the tranceiver’s and it saw all the zones which I labeled to the actual devices. While the VeraEdge can “see”
the DSC system, it cannot control it through the Vera App. Has anyone else run across this or used a cellular/BAT/CDMA transceiver? I’ve gone through the various threads testing solutions, but nothing works so far.
Thanks.
Ken ???
Have you been able to connect your security system to your VERA. I,’ curious what app you used which was able to pull your security system in VERA?
Thanks,
