Every time the vera reboots, the panel will do a double ding. Is there a way to disable that?
Running
UI7 and EVL3 App
Version:
4.00.21 EVL
EVL3 FW:
01.12.167A
Running
UI7 and EVL3 App
Version:
4.00.21 EVL
EVL3 FW:
01.12.167A
Does anyone else have this problem?
I had that problem with the dinging. It is caused by having the Output Relays mapped/enabled in the EVL3-Vista plugin. It was super annoying since any change in Vera causes a reload, and it would ding twice for each output I had mapped in this app. The solution is to Disable the outputs in the EVL3-Vista app.
http://forum.micasaverde.com/index.php/topic,27602.msg247782.html#msg247782
http://forum.micasaverde.com/index.php/topic,27602.msg247885.html#msg247885
Instead of using the output devices, use the RequestLetteredKeyPress method to control your garage door with the Vera.
I saw your other thread about garage door control through Vera and responded there already with the full details on how I have it setup.
Good luck…
James, Thank you so much for your reply. I was going nuts with all the dinging in the house always thinking it was someone getting into the house. I removed the mapping and now there is peace.
I have the Garage Door app installed to give me status and control of the garage door. It relies on device numbers to check the status of the door and another to change the state. How would I go about using the luup code to open/close it?
I will check out the links you provided in more detail.
thanks
boB
