Just started with vera3 and wonder if anyone help me transform a key switch to be part of zwave.
This keypad activated the different mode of a auto sliding door. It works with ir detecting motion and opening the door. The key switch will toggle different modes such as auto mode, open permanent or lock door. Should i be using a kind of binary module.
I suppose its a dry contact connection or very low voltage ?
