I’ve been wrestling with this issue for days.
I have 2 “Aeon Labs Door/Window Sensors”.
One is mounted on my front door and works perfectly.
The other (recent one I bought) is mounted on my garage door.
I’ve completely redone my entire network from scratch and the garage door sensor does not reliably report it’s state where the front door one does.
That said, IF THE SENSOR IS “AWAKE” IT REPORTS PERFECTLY. When I do awake stress tests the response time is really good. But after it leaves the ‘wake-up’ mode, I can barely be sure what state it’s in. Typically it seems to just be seriously delayed… Unlike the front door which is accurately instantaneous.
The topography is different for the two. The front door sensor is probably 10 to 20 feet from the Vera controller and is very near a in-wall Leviton dimmer.
The one in the garage is reasonably far and I would expect it to make one hop through another light switch. There are 3 switches within range of it. The closest being a GE Outdoor switch connected to a relay for the garage.
also, does the sensor report any neighbors under settings? are the light switches close “enough” to the garage sensor? I noticed that some of the door/window sensors have range issues, and really need to either be close to Vera or have close-by switches/dimmers.
Went into the garage and did some testing. Couldn’t be sure if my iPhone app response was just laggy due to bad network, or if it was the sensor.
I peeled off the magnet with the door open and repeatedly tripped and un-tripped the sensor. The state was mostly out of sync.
I’m guessing that the switch (about 3 feet away) is not repeating. Is there some way to tell if it’s repeating? Are known devices that are good to use as repeaters?
what if you move Vera temporarily next to the garage sensor, and see if the problems go away. if they do, then it’s the repeating, otherwise, might be something wrong with the sensor(?)
[quote=“electricessence, post:5, topic:172081”]Went into the garage and did some testing. Couldn’t be sure if my iPhone app response was just laggy due to bad network, or if it was the sensor.
I’m guessing that the switch (about 3 feet away) is not repeating. Is there some way to tell if it’s repeating? Are known devices that are good to use as repeaters?[/quote]
I had the same issue with my sensor. Actually my Vera Lua engine always crashed when assigning a route to this sensor. I am still in contact with MCV and they are looking into this odd issue. When my sensor talks directly to Vera everything works well. So I am not sure if this sensor is actually capable of using other nodes as repeaters. Maybe a firmware bug? I will let you know once I have more answers.
I too have the aeon labs door window sensor too and have noticed some strange things with mine too. I have the Veralite and I’m running the latest 408 firmware, but like you this problem was occurring before. The sensor has always been intermittent .
It got a little more confusing when I took it off the door and started to play with it more closely. To help the analysis I assigned a scene to the sensor that would play a sound file the sensor is tripped.
Tests so far show the following
separating the parts, LED blinks, it updates the UI (green to red man) and plays the sound
putting the parts back, LED blinks, it updates the UI (red man to green)
putting the parts back, LED blinks, but the UI is not updated and the red man stays
separating the parts, LED blinks, the UI stays red man but plays the sound
putting the parts back, LED blinks it updates the UI (red man to green)
This suggests to me tbat the UI is not being updated on the second opening and I have reproduced this a number or times now. Thoughts?
My one doesreport a neighbour, it has value 1 listed. It is about 2 meters from a dimmer switch
[quote=“parkerc, post:8, topic:172081”]I too have the aeon labs door window sensor too and have noticed some strange things with mine too. I have the Veralite and I’m running the latest 408 firmware, but like you this problem was occurring before. The sensor has always been intermittent .
My one doesreport a neighbour, it has value 1 listed. It is about 2 meters from a dimmer switch[/quote]
Had the same experience you mentioned. It is a pain to align this one properly (at least mine was).
I eventually replaced it with a Everspring sensor. MUCH better and reliable!
@parkerc:
Yeah, that sounds about right! Thanks for the detailed test.
It sucks because I really would like for this to be reliable. I wonder if trying a different sensor would help. Too bad they cost $50 a pop!
… @frichter09:
Ohh! Okay… I should just do that then.
I believe triple-click, so that the red LED stays on. The device is now awake and Vera should be able to talk to it. Triple-click again to put the sensor back to sleep (or wait 10 minutes), so that the LED is off.
