On my computer, on the Vera portal for my system, I can see my garage door sensor opening and closing via a small icon that goes red when open, and grey when closed.
This does not show up in the phone app though. So I have indication that the door is open or closed.
I do have some programs set up to send an alert when open at night or for more than xx amount of time.
Has anyone run into the phone app not showing the device open and close status? Any solution?
Ecolink Garage Door Tilt Sensor sz4f-6351v
urn:schemas-micasaverde-com:device:DoorSensor:1
D_DoorSensor1.xml
D_DoorSensor1.json
VeraPlus
The sensor works. I can see it and open/close indications on my computer UI, and I have an automation that reacts to it.
My phone app shows the device but does not show the open/close indication.
Zwave tilt sensor on the garage door.
The difference seems to be with the phone UI vs the computer portal UI
Hi @Edward_h
In order to resolve such behavior the category and sub_category of the device were changed, the correct values are:
- Category: 4
- Sub_Category: 1
If you have more questions let us know.
