I’d like to setup the following scenario but need some input on how it’s best accomplished:
Between the hours of 12am and 5pm, if any of the locks are left unlocked I would like VERA to SMS me.
Can someone provide the method of doing this?
Do you have a time line? In other words, if the doors are unlocked - AT ALL, or the doors are left unlocked for MORE THAN 5 MIN?
Good point. I think unlocked for 30 minutes would be fine.
…if I can join the club and with one stone kill 2 birds… ![]()
I have a scene that set a command to lock the door 30 minutes after the event door unlocked is sent.
It works well (simple scene: one event, one command) but I noticed that the “relock” command will be sent even if the door is already “relocked” ( I can ear the actuator; therefore it uses batteries for nothing).
What can be done to not do it if the door is already locked ? Another scene to cancel the first one (how do we do that?) when an event reports that the door is locked ?
And also send an SMS and/or email as requested by Markhc
so basically every half an hour I want to receive an SMS on cellular until someone locks the deadbolt.
Markhc
Your doorlock has no actuator ? (to lock it remote)
I’m using the schlage.
I think a part of the answer should be here:
http://forum.micasaverde.com/index.php?topic=3584.0
and another part here:
http://wiki.micasaverde.com/index.php/Luup_Scenes_Events
[code]Do something between 16:00 and 21:15:
local t = os.date(‘*t’)
local current_second = t.hour * 3600 + t.min * 60 + t.sec – number of seconds since midnight
local min_time_in_seconds = 16 * 3600 + 0 * 60 – 16:00
local max_time_in_seconds = 21 * 3600 + 15 * 60 – 21:15
if (current_second > min_time_in_seconds) and (current_second < max_time_in_seconds)
then
– do something
else
return false
[/code]
