Door lock graphic changed to a Jeep?!? WTH???
This is strange… this AM before I left for work, my MIOS dashboard showed the “lock” symbol for my front door and two garage doors. I took a look at work on my work laptop and suddenly it shows a picture of a Jeep Wrangler instead of the lock!?! Sounds like I need to somehow change the Door_Lock.png??? The unlock is still the opened padlock, so that is okay…
I just copied the link to the graphic that appears where my locked padlock used to be… https://fwd6.mios.com/remote/1.5.408-en/skins/default/icons/Door_Lock_100.png
THOUGHTS???
This one is pretty good. Best trouble with Vera post I’ve seen yet. Could you post a screenshot of the new icon?
Sorry I don’t have anything helpful to contribute.
[quote=“S-F, post:2, topic:175273”]This one is pretty good. Best trouble with Vera post I’ve seen yet. Could you post a screenshot of the new icon?
Sorry I don’t have anything helpful to contribute.[/quote]
That is the weird part… here is the link so just click on it → https://fwd6.mios.com/remote/1.5.408-en/skins/default/icons/Door_Lock_100.png .
Link shows up as normal lock.
  • Garrett
[quote=“garrettwp, post:4, topic:175273”]Link shows up as normal lock.
  • Garrett[/quote]
This is weird… same link shows up fine using IE but as a Jeep on Chrome. Virus? WTH?
Here is the graphic that appears using the link I mentioned (via Google Chrome)…
I would assume it might be an issue with your browsers cache getting messed up.
Have you attempted to clear the cache in Chrome for that site (or all of the cache, if you want)?
If you did not do this … then you should login to your Vera and see what else was modified at the same time … it looks like you have been hacked …
The file should be found on your Vera at:
/www/cmh/skins/default/icons
Except for downloaded plugins, the icons should be links to a file of the same name at:
/mios/www/cmh/skins/default/icons
[quote=“i814u2, post:7, topic:175273”]I would assume it might be an issue with your browsers cache getting messed up.
Have you attempted to clear the cache in Chrome for that site (or all of the cache, if you want)?[/quote]
Cleared cache for Chrome and issue is resolved. Thanks for the tip. I was thinking along those lines when it was okay with IE but wrong with Chrome.
This is still likely a software attack on your browser … caches do not just screw up!
