Hello !
I’m searching about a Zwave/Vera3 compatible Door lock what permits identity the code entered and realize an if/then process…
i.e…the password: 1234 executes open the door and executes an scene
the password 1235 open the door and executes another scene…
thanks…
AFAIK, I think all the Zwave locks supports this. It then just comes to preference of lock… whether you want a deadbolt style, or handle style, whether you want it motorized or not, and also how it looks.
Some locks support some features, better than others, and they all have pros and cons.
because my actual dead bolt lock style I’m thinking in buy this:
http://store.homeseer.com/store/Yale-D220ZW0BP-Oil-Rubbed-Bronze-Z-Wave-Touchscreen-Door-Lock-P1070C221.aspx
but is writted this:
Must be used with Z-Wave controllers that support “beaming”
has vera3 this resource ?
thanks !!!
Yes it does, but only if the lock is within range of Vera. If not then you need a powered Zwave device nearby that is also able to support this feature. This can be an Switch or appliance module!
OK ! My vera is in line sight of this door lock 6 meters.
