Looking for an idea on how to set up a door chime when my doors are opened. I have installed the sensors and looking for ideas for a chime.
What speakers are you intending to use?
I am personally using a TTS to announce which door has been opened through SONOS.
If you are looking for a stand-alone Z-Wave chime, the Dome siren/chime works well. It has 10 preloaded sounds ranging from a doorbell to various alarms, in addition to a traditional warning siren with LED strobe. It’s battery-powered and can be installed using the included double-stick foam tape. It pairs without issue and is fully integrated with U7.
Depending on your region, the Black Cat Message Centre will do what you want.
[url=https://www.blackcatcontrolsystems.com.au/Security-Sensors-CCTV-Detectors/Z-Wave-Enabled-Alarms/Black-Cat-Multi-Message-Centre]https://www.blackcatcontrolsystems.com.au/Security-Sensors-CCTV-Detectors/Z-Wave-Enabled-Alarms/Black-Cat-Multi-Message-Centre[/url]
The aeotec doorbell has several tones and chimes and can be loaded with mp3s for whatever sounds or announcements you want.
Fyi, it does require luup to control the mp3s.
[quote=“HSD99”]If you are looking for a stand-alone Z-Wave chime, the Dome siren/chime works well. It has 10 preloaded sounds ranging from a doorbell to various alarms, in addition to a traditional warning siren with LED strobe. It’s battery-powered and can be installed using the included double-stick foam tape. It pairs without issue and is fully integrated with U7.[/quote]Good solution and I like Dome products. I just wish the VeraSecure siren was as functional…
Sent from my SM-G950U using Tapatalk
Check this post. It uses the Aeotek doorbell and is a very good option, requiring just a little bit of code to make it work. Full instructions included in link.
http://forum.micasaverde.com/index.php/topic,50540.msg335250.html#msg335250
I probably should have mentioned that “fully integrated” with UI7 means that the device has direct control over the sounds via “pushbuttons”—no coding needed. When including the chime into a scene, you can select the desired sound from the built-in “pushbutton” controls.
