Hi, I’ve been trying Vera Concierge. It can turn lights on and off, but it doesn’t seem to be able to unlock doors.
In Assistant, it says “Unlock Lock:Front Door. What else ?” but nothing actually happens.
Any ideas?
The logs don’t really show anything (I x’d out a few numbers):
Oct 11, 2017 7:20:03 AM I:CSWebContainer:Action:LockAction Request:{“MyLock”:[“Lock:Front Door”],“CmdLock”:“Unlock”}
Oct 11, 2017 7:20:03 AM V:VeraService:Cmds:lu_action&DeviceNum=67&serviceId=urn:micasaverde-com:serviceId:DoorLock1&action=SetTarget&newTargetValue=Unlock
Oct 11, 2017 7:20:03 AM V:CSWebContainer:Cmd:/Request
Oct 11, 2017 7:20:03 AM I:VeraConnect.VeraGateway:URLConnection:https://vera-us-oem-relay41.mios.com/relay/relay/relay/device/xxxx/port_xxxx/data_request?output_format=json&id=lu_action&DeviceNum=67&serviceId=urn:micasaverde-com:serviceId:DoorLock1&action=SetTarget&newTargetValue=Unlock
Oct 11, 2017 7:20:04 AM I:VeraConnect.VeraGateway:URLConnection:https://vera-us-oem-relay41.mios.com/relay/relay/relay/device/xxxx/port_xxxx/data_request?output_format=json&id=lu_status2&DataVersion=731510096&LoadTime=1507731510
Oct 11, 2017 7:20:05 AM V:VeraService:ParseLuStatus:1
Oct 11, 2017 7:20:05 AM V:CSWebContainer:Cmd:/Log
Oct 11, 2017 7:20:07 AM I:VeraConnect.VeraGateway:URLConnection:https://vera-us-oem-relay41.mios.com/relay/relay/relay/device/xxxx/port_xxxx/data_request?output_format=json&id=lu_status2&DataVersion=731510106&LoadTime=1507731510
