Hi guys, I am planning to gradually get into Sonos ecosystem…probably will start with PLAY1…
However in the plugin documentation on the supported devices it shows up only 3 & 5…so wanted to know if the plugin supports PLAY1 and good to start with…
I have been looking for multiroom system integrated with Vera for quite sometime and wanted to go with Sonos mainly because of this wonderful plugin… Your inputs are much appreciated…
Yes it should work fine with the play 1. The play 1 just came out. But is no different than the other models for control.
- Garrett
