Hi all,
I see in that wiki that ReverseOnOff can be used in a luup code.
Does it possible to use it as a variable in a device, as I have to invert all my fibar window covering devices.
Hi all,
Did you have any luck with this? It may work to use ReverseOnOff as all Z-Wave window covering motor controllers are using the Multi-level Switch Class so they are essentially lighting dimmers to Vera. Or you might have luck modifying the xml device file “D_WindowCovering1.xml”
