Just a quicky - pretty much as the subject states.
Am wondering if I use 10 device variables in PLEG instance A and also watch them in a further PLEG instance B, are there built in efficiencies in the underlying PLEG/LOGIC code to only create 10 variable watches…or are 20 created ?
David
A Variable watch is only created when there is an INPUT defined for a trigger or a property.
Thanks - I get that, however, would there be TWO variable watches created in the system with this example ? Or is it 1 variable watch that’s created and then referenced by each PLEG instance ?
Once again … there is a Variable watch for an INPUT
When you export a Condition … it’s NOT an input!
