Meaning you want to be able to control the devices paired on your Ezlo hub via HA Bridge ?
So you would need to be able to add those Ezlo devices into HA bridge etc.
I haven’t tried it but it might be possible to manually added an Ezlo device in to HA bridge and using the Ezlo HTTP Server API URL commands etc to control that device.
I forget fully how Vera worked with HA Bridge and Alexa.
You might want to start by looking at this thread where I explain how to use the HTTP API on Elzo hubs.
Once you have your URL commands figured out you could add them in to a new device on the HA bridge etc.
