Does anyone find Vera can't change the fan on Wayne Dalton Thermostat?
Is anyone else finding that the fan setting isn’t affected by Vera?
I’m running 1.1.28 and have the stat set on Auto.
I can’t change it to stop running the fan if on, or to start running the fan if it is off.
Any ideas or suggestions?
Thanks!
My understanding is that the fan control on the WD is hardwired only… Zwave cant be used to control that. It can only control Temp Settings and switch between heat/cool/off.
I just keep mine set for fan to be on Auto.
Correct…it is hard wired on the WDTC-20.
I’m hoping someone can tell me if there is an upgrade to 1.1.228 so I can control the thermostat without adding and subtracting 27 degrees.
Help!!
Now that’s weird…I run 1.1.228 and My WDTC-20 works perfectly. Is it configured correctly?
Even if you send a set point, you don’t have to subtract 27 degrees?
So here’s a wild thought–and probably off-base. For those for whom this seems to work, are you on Celsius? And those for whom it’s off, Fahrenheit?
–Richard
Hi all,
This was fixed and it’s working ok. Please wait for the firmware release and you won’t stumble into this problem anymore.
Not a F/C issue. It’s -27F constant. I was using UI2 (.979) and they fixed the problem last week. Now we’re just waiting for UI3 to catch up.
