Display pin codes for Schlage lock
Is there a way to display in list format all of the pin codes created for my Schlage lock?
The check box Show pin codes in clear does nothing on my iPad.
I have a Schlage FE599 NX handle lock connected to a Vera Lite installed 10/2015
I have the same issue!
Have same issue with
Schlage 469NX firmw 6.8
Vera2 UI5
my PC runs Win 10
Thank you
Seems to work the first time you to do it, but if you look at the properties again, the PIN is missing.
Here’s the workaround I do…when I create a new user, I put the PIN in () next to the name.
So I have
Timmy (1234)
Jimmy (2345)
etc. as the names in Vera so the PIN is always shown.
Vera - can you respond to this issue?
Hi Sloanish –
I think you’ll find that except for Marc the MCV folks do not monitor this forum. If you need to have it fixed, call or email MCV…
Sorry,
Don
I sent them a ticket 3 days ago but had no response so far
maybe another member of this forum having same issue could also contact Vera ?
Thank you
Hi all,
I opened a new ticket and this was answered MCV
here is what they sent me :
[i]"Did you tried adding the pin codes directly from the Web interface ?
They will not show up if you?ve added on the door lock and in some cases if there are already pincodes stored on the door lock.
I recommend you to exclude the door lock from the Z-Wave network then reset it according to the instructions from the manual then include it again and set the pincodes from the Vera?s web interface.
Please let me know how it goes "[/i]
In fact my door lock is far away from my home location… so if someone here could test what MCV advice, and let me know so I could give them some feedback
thank you
[quote=“tbailey1712, post:4, topic:189512”]Seems to work the first time you to do it, but if you look at the properties again, the PIN is missing.
So I have
Timmy (1234)
Jimmy (2345)
etc. as the names in Vera so the PIN is always shown.[/quote]
Im having the same issue. ill use this suggestion in the mean time.
I’m having the same issue with my VeraEdge and the Schlage BE469NX lock. Pin Codes “Code 1” and “Code 2” show ****. “Code 3” does not display anything. We have many codes but none show.
Welcome to the club, Vera has been absolutely useless. They provided canned responses rather that actual solutions for all of my issues. I will be looking for a system that actually works and does what it is supposed to. I have found though that if I program lock pins on the same network they show up. If they are programmed remotely then nothing shows up.
Thanks for the tip! Mine were programmed remotely - I’ll try programming it using Vera. (I’m using more than 4 digits - hope it can handle that.)
Very strange thing happens…adding pin through Vera interface to my Veralite. I get a “Success!..” message but if i wait a minute the name & pin disappear.
I discovered that the lock was only set for 4 digit pins. In the Advanced settings on the Vera Interface I am able to change the max. pin from 4 to 7. It says it is set to 7 but the lock only accepts 4 digits.
I am going to reset the lock to a factory reset to see if I can fix the issue.
UPDATE:
Running Firmware Version: 1.7.902
Schlage Deadbolt
BE469NX
Variables
(Set to match both min. & max. digit code sizes of PINS)
MinPinSize: 7
MaxPinSize: 7
All is working fine now. I am able, from Vera interface, add/remove PINS.
