Disarming, logs not showing
Is there way to disarm the GE Nx8e system in Vera 3, I can quick arm and quick stay via the plugin, but wanted to setup a trigger that if the quickset zwave door is unlocked via unlock pin code entered on the lock , the alarm system is disarmed etc. etc.lights thermostat…
Also any advise on getting the most recent logs from the panels activities, my plug in does not show the logs from the panel.
I was not able to scan the zones or users and get info, but could add manually and working.
Integrating the GE system to my Vera3 was my last challenge frontier to this system, and seems things are working as wanted so far.
Thanks!
http://forum.micasaverde.com/index.php/topic,9374.msg62056.html#msg62056 (this is for a different brand of panel but the steps are identical).
Double-check that you have enabled the message “Log Message” (hex 0A) in the panel configuration. If you are still experiencing an issue then I need you to capture a Luup log and send it to me.
Since JavaScript is involved there may also be a dependency on which browser you are using and whether you are on Vera’s LAN or remote. Experiment with these variables too.
You’re not the first to report this. Unfortunately since it is usually newcomers who experience this problem, they are unable to help me to reproduce it, so it goes unsolved. You’ve already figured out the workaround, good.
futzle,
I was able to scan the zones or users and get info when I originally installed the plugin months ago - lately every time I try it get stuck in getting results… I would like to help you debug this - let me know what you need.
regards
harry
Thanks for the offer. First port of call would be a Luup log of a zone scan. Ensure that you’ve enabled Debug to Luup Log on the Configure tab first.
Other things I will need to know: the browser(s) you used; whether you are doing this from the LAN or from the Internet; how many instances of the top-level device you have (should be 1); version of the plugin you have installed.
futzle,
After reading thru the multiple post I decide to reroute and cleanup my USB/Serial cable to see if that helps with the issue. After separating and organizing the cables now I can read the user configuration without any issues. The only item I still have trouble now is when I request to Arm the alarm, then disarm, then arm again within a short period (< 5 min) I start getting a bunch of drop packages and checksum failures - to me it look like the communication between the alarm and Vera gets overwhelm and the only way I can recover that is to reload Luup.
I’m using Windows8 with Chrome - I have plugin Rev #68 with the latest version L_CaddxNX584Security.lua and I_CaddxNX584Security.xlm - i think #70
I’m running UI5, all commands local from Vera but I get same results from HomeBuddy Android application. I have a GE NX8E - with built in serial port - with 5 doors and 3 motion detectors - all wired
Let me know if there is any other information you need.
If you can get me a Luup log of the exchange (use a sacrificial PIN because it will be in the logs) send it over.
Futzle,
User scanning does not work again, looking at the lots I see the following error in the UserScan function - after reloading Luup still does not work. Partial logs are included below.
01 05/29/13 21:20:35.877 LuaInterface::CallFunction_Request function callbackHandler name UserScan failed [string “–…”]:1331: attempt to index local ‘u’ (a nil value) <0x2ff80680>
01 05/29/13 21:20:36.178 InsteonSerial::Send m_iFrameID 890 command 0x62 response 0 failed to get at time 18848178 start time 18843178 wait 5000 m_iSendsWithoutReceive 0 <0x2c67b680>
01 05/29/13 21:20:36.525 LuaInterface::CallFunction_Request function callbackHandler name UserScan failed [string “–…”]:1331: attempt to index local ‘u’ (a nil value) <0x2e8bc680>
01 05/29/13 21:20:36.789 LuaInterface::CallFunction_Request function callbackHandler name UserScan failed [string “–…”]:1331: attempt to index local ‘u’ (a nil value) <0x2e8bc680>
01 05/29/13 21:20:40.425 LuaInterface::CallFunction_Request function callbackHandler name UserScan failed [string “–…”]:1331: attempt to index local ‘u’ (a nil value) <0x2ff80680>
01 05/29/13 21:20:40.840 LuaInterface::CallFunction_Request function callbackHandler name UserScan failed [string “–…”]:1331: attempt to index local ‘u’ (a nil value) <0x2eabc680>
01 05/29/13 21:20:41.368 LuaInterface::CallFunction_Request function callbackHandler name UserScan failed [string “–…”]:1331: attempt to index local ‘u’ (a nil value) <0x2ff80680>
01 05/29/13 21:20:42.675 LuaInterface::CallFunction_Request function callbackHandler name UserScan failed [string “–…”]:1331: attempt to index local ‘u’ (a nil value) <0x2eabc680>
01 05/29/13 21:20:43.313 LuaInterface::CallFunction_Request function callbackHandler name UserScan failed [string “–…”]:1331: attempt to index local ‘u’ (a nil value) <0x2eabc680>
01 05/29/13 21:20:43.793 LuaInterface::CallFunction_Request function callbackHandler name UserScan failed [string “–…”]:1331: attempt to index local ‘u’ (a nil value) <0x2ff80680>
01 05/29/13 21:20:45.342 LuaInterface::CallFunction_Request function callbackHandler name UserScan failed [string “–…”]:1331: attempt to index local ‘u’ (a nil value) <0x2ff80680>
01 05/29/13 21:20:45.826 LuaInterface::CallFunction_Request function callbackHandler name UserScan failed [string “–…”]:1331: attempt to index local ‘u’ (a nil value) <0x2eabc680>
01 05/29/13 21:20:46.491 LuaInterface::CallFunction_Request function callbackHandler name UserScan failed [string “–…”]:1331: attempt to index local ‘u’ (a nil value) <0x2ff80680>
50 05/29/13 21:27:01.451 luup_log:169: ZoneScan job handling message: 0x04 Zone Status <0x2fae9680>
50 05/29/13 21:27:01.451 luup_log:169: ZoneScan Zone 5 <0x2fae9680>
50 05/29/13 21:27:01.451 luup_log:169: Valid zone 5 <0x2fae9680>
50 05/29/13 21:27:01.452 luup_log:169: Finishing pending job userdata: 0xb7a8d8 <0x2fae9680>
50 05/29/13 21:27:01.651 luup_log:169: callbackHandler: request ZoneScan <0x2ff80680>
50 05/29/13 21:27:01.651 luup_log:169: callbackHandler: format json <0x2ff80680>
50 05/29/13 21:27:01.909 luup_log:169: Job: Alarm: ZoneScan: 169 6 job userdata: 0xd74c70 <0x2b547000>
50 05/29/13 21:27:01.921 luup_log:169: Job: Processing send queue <0x2b547000>
50 05/29/13 21:27:01.923 luup_log:169: Message: Outgoing: 0x7e 0x02 0x24 0x05 0x2b 0x53 <0x2b547000>
50 05/29/13 21:27:01.925 luup_log:169: Job: Started <0x2b547000>
50 05/29/13 21:27:01.993 luup_log:169: Received good message 0x04 <0x2fae9680>
50 05/29/13 21:27:01.994 luup_log:169: Message: Incoming message body: 0x05 0x01 0x58 0x13 0xf0 0x00 0x02 <0x2fae9680>
50 05/29/13 21:27:01.994 luup_log:169: ZoneScan job handling message: 0x04 Zone Status <0x2fae9680>
50 05/29/13 21:27:01.995 luup_log:169: ZoneScan Zone 6 <0x2fae9680>
50 05/29/13 21:27:01.996 luup_log:169: Valid zone 6 <0x2fae9680>
50 05/29/13 21:27:01.996 luup_log:169: Finishing pending job userdata: 0xd74c70 <0x2fae9680>
50 05/29/13 21:27:02.151 luup_log:169: callbackHandler: request ZoneScan <0x2eabc680>
50 05/29/13 21:27:02.151 luup_log:169: callbackHandler: format json <0x2eabc680>
50 05/29/13 21:27:02.395 luup_log:169: Job: Alarm: ZoneScan: 169 7 job userdata: 0x115f570 <0x2b547000>
50 05/29/13 21:27:02.395 luup_log:169: Job: Processing send queue <0x2b547000>
50 05/29/13 21:27:02.396 luup_log:169: Message: Outgoing: 0x7e 0x02 0x24 0x06 0x2c 0x54 <0x2b547000>
50 05/29/13 21:27:02.397 luup_log:169: Job: Started <0x2b547000>
50 05/29/13 21:27:02.437 luup_log:169: Received good message 0x04 <0x2fae9680>
50 05/29/13 21:27:02.437 luup_log:169: Message: Incoming message body: 0x06 0x01 0x58 0x13 0xf0 0x00 0x02 <0x2fae9680>
50 05/29/13 21:27:02.437 luup_log:169: ZoneScan job handling message: 0x04 Zone Status <0x2fae9680>
50 05/29/13 21:27:02.438 luup_log:169: ZoneScan Zone 7 <0x2fae9680>
50 05/29/13 21:27:02.438 luup_log:169: Valid zone 7 <0x2fae9680>
50 05/29/13 21:27:02.439 luup_log:169: Finishing pending job userdata: 0x115f570 <0x2fae9680>
50 05/29/13 21:27:02.657 luup_log:169: callbackHandler: request ZoneScan <0x2ff80680>
50 05/29/13 21:27:02.657 luup_log:169: callbackHandler: format json <0x2ff80680>
50 05/29/13 21:27:02.900 luup_log:169: Job: Alarm: ZoneScan: 169 8 job userdata: 0x1162048 <0x2b547000>
50 05/29/13 21:27:02.901 luup_log:169: Job: Processing send queue <0x2b547000>
50 05/29/13 21:27:02.901 luup_log:169: Message: Outgoing: 0x7e 0x02 0x24 0x07 0x2d 0x55 <0x2b547000>
50 05/29/13 21:27:02.902 luup_log:169: Job: Started <0x2b547000>
50 05/29/13 21:27:02.947 luup_log:169: Received good message 0x04 <0x2fae9680>
50 05/29/13 21:27:02.948 luup_log:169: Message: Incoming message body: 0x07 0x01 0x58 0x13 0xf0 0x00 0x02 <0x2fae9680>
50 05/29/13 21:27:02.948 luup_log:169: ZoneScan job handling message: 0x04 Zone Status <0x2fae9680>
50 05/29/13 21:27:02.949 luup_log:169: ZoneScan Zone 8 <0x2fae9680>
50 05/29/13 21:27:02.949 luup_log:169: Valid zone 8 <0x2fae9680>
50 05/29/13 21:27:02.958 luup_log:169: Finishing pending job userdata: 0x1162048 <0x2fae9680>
50 05/29/13 21:27:03.170 luup_log:169: callbackHandler: request ZoneScan <0x2e8bc680>
50 05/29/13 21:27:03.171 luup_log:169: callbackHandler: format json <0x2e8bc680>
50 05/29/13 21:27:03.715 luup_log:169: callbackHandler: request ZoneScan <0x2e8bc680>
50 05/29/13 21:27:03.716 luup_log:169: callbackHandler: format json <0x2e8bc680>
elordude, partial logs are partially helpful. Clearly there’s something around line 1331 which needs hardening against an unspecified error situation that started before the capture. I promise to stare at that line of code and see if I can imagine how it’s failing. Meanwhile, your homework: more complete logs will provide a more complete picture. Preferably start capturing just before you attempt whatever it is that is failing (such as visiting the Users tab).
