I use a Vera Plus gateway for a long (more than 4 years), only to support my Zwave devices network.
Recently I started to use Zigbee 3.0 devices, that cannot be supported on Vera (unfortunatelly).
The only solution was to buy a new gateway, to support the zigbee network.
In order to avoid interference, I need to disable the Zigbee radio on Vera. How can I do it? I cannot find any option on the interface related. Can this be done via SSH?
No need do disable anything, multiple zigbee networks can happily coexist (and share the spectrum with WiFi, Bluetooth etc). Each zigbee networks has its own unique identifier.
I know that they can coexist, but the signal degradation is not acceptable. The gateways are close together.
If I poweroff Vera, I get a significant improve on sensor LQI values. The problem is that i simply can’t disconnect Vera, as I need it to support the Z-Wave network
Do anybody knows how to do it, via SSH?
