Hi all,
I use a fibaro double switch as an indicator not as a switch (the actual switching is done by a relais). The system is working fine, as long as I don’t change the switch myself.
My question: Is there a possibility to disable the use of a fibaro switch so I can’t change it within VeraEdge.
Thx for your reply. As you already assumed, I want to see the status of the relais but not being able to change it within Vera. So I can’t hide the device.
You have to develop a custom device file. I have one to simulate a sensor attached to a relay. I can share if you want it and the mobile app will show it nonetheless. Your other way is to use a virtual sensor, copy the value via code and hide the original one. This will be 100% compatibile with mobile apps.
