hello guys, i wonder how can i disable fibaro dimmer light in the ui5 interface from turning on? cause i don’t want to take the dimmer out of the wall… because i’m using now fluorescent light and i can’t turn if off without the light flicks all night…
You can configure the Fibaro FGD-211 dimmer so that it will act as an on/off switch for use with fluorescent and CFL lamps. It tells you what parameters to set in the instruction sheet. I have also found it necessary to fit a Fibaro Bypass device (FGB-001) across the load to stop CFLs flickering when turned off.
