Yes I thought about doing that as I used to do exactly the same thing when I was using it with IR by mapping it to something else, but the problem is that the user has to actually select 10 when picking this from a scene, or within SQ remote, and the problem will be the same for any other AV Plugin that uses it. Also If we hack it now with 10 (or anything else) it now means we should also probably make it right in the future if MCV ever fixes it, and I’d rather just do it once by getting confirmation from MCV that the underlying problem can be fixed, or that they can allow the use of “_” or “Dash” and edit S_Tuning1.xml in the next release.
Given that dash button is needed for folks with the AM21 (Off Air Receiver / OTA) and other uses (useful for giving SWM/Internet status and maybe rebooting the box), I think we should just put pressure on MCV to fix it in the next firmware due to the fact it effects all other AV Plugins still. They just need to either edit the file to remove the - – characters from around the _ or just add _ on a new line like I did (or alternatively the word “Dash”).
I’d also like to see it fixed as occasionally I use the dash for confirmation of a box reboot.
@mcvflorin, input appreciated please!?
