I have had a working network of switches for a couple of weeks
Recently the physical switches stopped triggering a scene.
Here is what does not work
If switch 1 is turned off then turn off switch 1, switch 2, switch 3 …
Here is what does work
Hitting the play button on via veralite properly turns off all the lights
Switch 1 controls the local load properly but does trigger the scene
The veralite soft switches all correctly control the loads
It’s almost as if the button signal doesn’t get to veralite properly
All the switches a leviton VRMX1-1LZ
Any ideas?
