Dimmers and switches - Additional devices are created in Vera
I have an issue when I’m installing Fibaro dimmer 2 (and also other switches). The dimmers or switches creates multiple devices. See the picture to understand what I mean. All dimmers marked with yellow are additionals, whereas the four on top are the once I’m using.
This is quite disturbing in the Vera Edge UI. Can anyone help me in how to hide or delete these additional devices?
Screenshot from Vera Edge: [url=https://drive.google.com/file/d/0BxIOrBGoenVqU1Y0bHlsMkFWcHM/view?usp=sharing]https://drive.google.com/file/d/0BxIOrBGoenVqU1Y0bHlsMkFWcHM/view?usp=sharing[/url]
Ohh, after serching for a solution for quite some time, I found a solution just minutes after posting this question on the forum.
The solution is to execute the following code:
luup.attr_set(“invisible”,“1”,device id)
In Vera Edge this is done under Apps - Develop Apps - Test Luup code
:slight_smile:
